Setting up Vectorworks Remote
The Vectorworks Remote app allows you to control the Vectorworks application from your mobile device. Vectorworks Remote has two components: the Vectorworks Remote mobile app and a Vectorworks Remote connection plug-in, which is included in Vectorworks as a menu command. When the two components are connected, the app displays a list of remotes. Interactively use the remotes to view, navigate, and present designs on your computer. For more information, visit cloud.vectorworks.net/products/remote/faq/.
To set up Vectorworks Remote, first install the Vectorworks Remote app on your mobile device.
To establish the remote connection:
  1. Select Tools > Utilities > Vectorworks Remote.
  2. The Vectorworks Remote Setup dialog box opens.
  3. Open the Vectorworks Remote mobile app and connect to Vectorworks using one of the methods provided on the initial screen of the app.
  4. The Vectorworks Remote app help contains more detailed instructions on how to connect to Vectorworks.
  5. When the connection is established, click OK to close the Vectorworks Remote Setup dialog box.
