ArchLand00003.pngAdding Source Data with 2D Polygons or Polylines
Another way to generate the site model source data is to draw, trace, or import 2D polygons or polylines representing contours; then use the 2D Polys to 3D Source Data command to convert the polygons or polylines to 3D polygons or 3D loci.
The Modify by Record command can convert 2D polygons or polylines with attached record elevation data directly to 3D polygons at the proper elevation. See Modifying Objects by Record Value.
To generate source data with the 2D Polys to 3D Source Data command:
  1. Create or import the 2D polygons or polylines representing contour lines.
  2. Select the 2D Polys to 3D Source Data command from the appropriate menu:
  3. ●    Landmark workspace: Landmark > Survey Input > 2D Polys to 3D Source Data
    ●    Architect workspace: AEC > Survey Input > 2D Polys to 3D Source Data
    The 2D Polys to 3D Source Data dialog box opens. Enter the first elevation and change in elevation between contour lines, specify the smoothness of the source data conversion, and then select the type of object to be created.
  4. Click OK.
  5. The Set Elevation dialog box opens, and the first polygon or polyline in the drawing order is highlighted. If necessary, use the Up or Dn buttons to set the elevation of the highlighted polygon or polyline, and then click Next. When prompted, indicate whether to delete the original items.
  6. Repeat for all of the polygons or polylines in the drawing.
To interrupt this process, click Done. To resume setting elevations, select the starting polygon or polyline and select the 2D Polys to 3D Source Data command.
Either 3D polygons or loci are created from the polygons or polylines, with Z values equal to the assigned elevations. These Z values can be edited from the Object Info Palette if they are incorrect.
Site Model Source Data
Validating 3D Source Data
Simplifying 3D Polygons
Creating the Site Model
