Stair
Settings: Graphic Attributes TabThe settings on the tab can be saved as a set and then loaded, replacing the current tab parameters.
Click the Graphic Attributes tab to specify the appearance of stair components.
The graphic attributes of each stair part are listed. Double-click an item to edit it.
An Attributes dialog box with the name of the item is displayed. See The Attributes Palette for information on setting attributes.
Set the attributes and click OK to return to the Graphic Attributes tab.
