Redefining
Saved ViewsTo change the content of a saved view, use the Redefine command. This changes the saved view settings to match those of the current drawing area view, including the current layer options and class options, the plan rotation, the visibility of layers and classes that are inactive, and the active layer and class.
To redefine a saved view:
From the Navigation palette, select the Saved Views tab.
Select the view to be changed from the list.
From the Navigation menu or the view context menu, select Redefine.
The Redefine Saved View dialog box opens. Specify the view options and the visibility parameters.
Click OK to save the current drawing area view with the specified settings.
