Mapping Layer and Class Names
Prior to import and export operations, map the DXF/DWG or DWF layers to Vectorworks classes or layers as desired. Use AIA standard layer names, or create a custom set of names. Save custom mapping sets for specific clients for easier file import and export.
When multiple classes are exported into a single layer through mapping, the objects maintain their original attributes by having their attributes set to object instead of set to class.
Custom mapping sets and standards are saved in your user folder ([User]\Libraries\Defaults\DWG_DXF), and they are used for both import and export.
Creating and Editing Mapping Sets
To create and configure mapping sets:
  1. Access the mapping dialog box during either import or export operations, as follows:
  2. ●        From the DXF/DWG Import Options (or DWF Import Options) dialog box, click Advanced. From the Advanced DXF/DWG Import Options (or Advanced DWF Import Options) dialog box, open the Classes/Layers pane, and click Manage under the Classes/Layers heading.
    ●        From the DXF/DWG Export Options (or DWF Export Options) dialog box, click Manage under the Class/Layer Mapping heading.
    The Import (or Export) Layer Mapping dialog box opens. The import and export settings are slightly different.
  3. Select a Mapping Set to edit, and select a Standard set of names to use for mapping.
  4. The mapping list at the bottom of the dialog box displays all items to be mapped from the file being imported or exported. To map an item, select it, and then select the name to map it to from the pull-down list of class/layer names.
  5. ●        During import, assign a standard class or layer name to the DXF/DWG or DWF layer being imported.
    ●        During export, assign a standard layer name to the Vectorworks class or layer being exported.
  6. When finished mapping, click Save and name the mapping set.
Creating and Editing Standards
To create and edit standards:
  1. During either import or export operations, click Manage under the Mapping heading in the Import (or Export) Layer Mapping dialog box.
  2. The Edit Standards dialog box opens.
  3. Edit the names in the list as needed.
  4. When finished editing, click Save and name the set of standards.
DXF/DWG and DWF Export Options
Sharing Custom Content Using Workgroup Folders
