DesignSeries00045.pngInserting Fastener Objects Using the Fastener Tool
Tool
Tool set
Fastener
Fasteners
Several types of fastener objects can be inserted by clicking the Fastener tool and specifying object parameters from the Tool bar.
The following modes are available.
Mode
Description
Screw or Screw/Washer/Nut Combination
Inserts a screw and nut object which can be composed of a variety of screw, washer, and/or nut components; hex bolts, square bolts, hex screws, cap screws, and machine screws can all be inserted using this tool mode
Nut
Inserts a nut object, including hex, hex jam, slotted hex, and square nuts
Plain Washer
Inserts a plain washer object
Lock Washer
Inserts a lock washer object
Shoulder Screw
Inserts a shoulder screw object
Set Screw
Inserts a set screw object
2D Front View
Inserts the selected item as a 2D object in front view
2D Side View
Inserts the selected item as a 2D object in side view
2D Top View
Inserts the selected item as a 2D object in top view
2D Bottom View
Inserts the selected item as a 2D object in bottom view
3D Object
Inserts the selected item as a 3D object
ASME Inch
Inserts the selected object using ASME inch standards
ASME Metric
Inserts the selected object using ASME metric standards
ISO
Inserts the selected object using ISO standards
DIN
Inserts the selected object using DIN standards
Preferences
Opens the Preferences dialog box for specification of additional object parameters
To insert a fastener object:
  1. Click the tool and click the desired fastener object.
  2. Click the Tool bar button to insert either a 2D object in a specific view or a 3D object.
  3. For objects that do not have bottom view (because it is the same as the top view), the top view is drawn when either the 2D Top View or 2D Bottom View mode is clicked. The same applies to the front and side view.
  4. Click the Tool bar button to insert the object using ASME (inch or metric), ISO, or DIN standards.
  5. Click Preferences to specify additional object parameters before placing the object in the drawing. Parameters vary based on the object selected for insertion, and show the available variations for a specified object size. Additional parameters display in the Object Info palette. Refer to the following table for detailed object parameter information.
  6. If inserting a linear object (such as a bolt, screw, or screw and nut object), click in the drawing area to set the start point, drag to set the object’s length, and click again to set the object’s end point. For all other objects (such as washers and nuts), click in the drawing area to place the selected point object.
After placement, fastener objects can be edited from the Object Info palette.
Screw or Screw/Washer/Nut Combination Parameters
Nut Parameters
Washer Parameters
Screw Parameters
Fastener Object Thread Styles
