Command |
Path |
Import Cinema 4D Textures |
File > Import |
Cinema 4D textures can be imported for use as a resource in Vectorworks files, even if you do not own a copy of Cinema 4D. The imported textures can be edited from the Edit Texture dialog box (see Editing Textures and Shaders from the Resource Manager).
To import Cinema 4D textures:
Select the command.
The Choose Cinema 4D dialog box opens.
Select the file with the textures to import.
The Vectorworks software creates a texture resource folder with the same name as the source Cinema 4D file. The textures are placed in the folder, which is accessible from the Resource Manager.
