Command |
Path |
Import Rhino 3DM (3D only) |
File > Import |
During Rhino 3DM import:
● Points are imported as a group of 3D loci.
● NURBS curves are imported as a group of NURBS curves.
● NURBS surfaces are imported as a group of NURBS surfaces.
● Closed solids are imported as a group of imported solids
● Open solids are imported as a group of NURBS surfaces.
● If there is only one element in the Rhino 3DM file, it is imported as a single element rather than grouped.
Imported solids cannot be ungrouped or edited through the Edit Group command; they can be used in solid operations.
To import a Rhino 3DM file:
Select the command and then the file to import.
