Importing STL (3D only)
Command
Path
Import STL (3D only)
File > Import
The Vectorworks program imports Stereolithography (STL) files, which are widely used for 3D printing, prototyping, and manufacturing. Polygon mesh objects import into a Vectorworks file as mesh objects.
To import an STL file:
Select the command and then the file to import.
Alternatively, click the file to import and drag it into an open Vectorworks file.
Editing Mesh Objects
