Irrigation SettingsCommand |
Path |
Irrigation Settings |
Landmark > Irrigation |
Prior to beginning an irrigation design, set up the default irrigation settings. The irrigation settings apply to the current file.
Click Reset to return all irrigation settings to their default values.
To specify the irrigation settings:
Select the command
The Irrigation Settings dialog box opens.
The unit and precision settings here override the Units specified in the document settings, and apply only to the irrigation components of the drawing. Specify the unit and precision value for the size (small dimensions of components, such as pipe diameter), distance (measurements for larger items such as throw distance), angle, pressure, flow rate, and velocity measurements. For any of the units of measurement except the angle, a custom unit can be specified; see Creating a Custom Unit System.
Click the Pipes/Tubing tab.
Click
to show/hide the parameters.
Click the Zoning tab.
The settings on this tab apply to design zones (see Creating Design Zones). Select the zone numbering method, and then choose the classes for identifying overlapping coverage or areas without any coverage.
Click
Click the Classing tab.
The settings on this tab control whether the various irrigation objects, and in some cases, sub-objects, are automatically assigned to classes, and assign the class names to the objects. The assigned classes are created in the file as the objects are added.
Click
