Command |
Path |
Rotate 3D |
Modify > Rotate |
The precision of the rotation values that can be entered (degrees, minutes, and/or seconds) depends on the Units setting.
To rotate at custom angles in 3D:
Select the 3D object or objects to rotate.
Select the command.
The Rotate Object in 3D dialog box opens. Specify the rotation parameters.
Click
to show/hide the parameters.
