Custom Rotation
Command
Path
Rotate
●        Modify > Rotate
●        Double-click the Rotate Tool
The center of rotation for this command is limited to the center of the object’s bounding box. The rotation is performed within the screen plane.
To rotate by a custom angle:
  1. Select the object or objects to rotate.
  2. Select the command.
  3. The Rotate Object dialog box opens.
  4. Enter the rotation angle.
The precision of the values that can be entered (degrees, minutes, and/or seconds) depends on the Units setting.
Rotating Objects
