Preset Rotation Angles
Command
Path
Rotate
●        Modify
●        Context menu
The rotate commands provide a number of ways to rotate objects in the screen plane without changing their base location in the drawing. Select one of the preset rotation angles, or specify a custom rotation angle.
To rotate at a specified angle:
  1. Select the object to rotate.
  2. Select the command, and then select one of the pre-set rotations.
Rotating Objects
