Mode  |
		Tool  |
		Tool set  |
Modes for Creating Lines  |
		Break Line
		Dims/Notes  |
The Break Line tool creates one of three types of break lines: straight, curved, or arc.
On site models, pads with open edges, sometimes called break lines, can be created using the Site Modifier tool (Vectorworks Architect or Landmark required). See Creating a Pad or Pad with Retaining Edge.
To draw a break line:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default properties. The properties can be edited from the Object Info palette.
Click
 to show/hide the parameters.
