Command |
Path |
Line into Segments |
Modify > Drafting Aids |
The Line into Segments command converts a selected line into the indicated number of equal length segments. The original line can be converted, or an identical line placed on top of the original and converted.
To convert a line into segments:
Select the line to be converted.
Select the command.
The Line into Segments dialog box opens.
Click
to show/hide the parameters.
Set the parameters and draw either a new segmented line or convert the selected one.
