Property
Line ParametersProperty line preferences can be set before the property line object is inserted in the drawing in the object properties dialog box; access it by clicking the Property Line tool and then clicking the Preferences button from the Tool bar. These preferences serve as the new default for property lines inserted in the drawing until the preferences are changed.
Parameters can be edited for selected property line objects after placement, in the Object Info palette.
Edit the shape of selected property lines by using the Reshape tool, or by clicking the Edit with Dialog button from the Object Info palette. See Reshaping Objects for information on using the Reshape tool for editing.
Click
to show/hide the parameters.
If the property line is designated to be a texture bed on the site model, select Tools > Organization. On the Classes tab, select the class designated as the texture bed class, and assign it a distinctive fill color or a texture. Select the site model and click Update from the Object Info palette; the property line displays as a texture bed on the site model. Switch to a 3D view and render for the full effect.
