Managing
Stair StylesIn the Stair Settings dialog box, the 2D Graphics, Construction, Railings, and Graphic Attributes tabs have the option of saving the current tab’s settings as a style that can be recalled later. The stair minimum/maximum settings can also be saved as a style set.
To save tab settings as a style:
When the tab parameters have been set, click Save (located in the Styles area at the top left of the tab). The Save Style dialog box opens.
Click
to show/hide the parameters.
The new style name appears in the Styles list.
To recall a saved style:
Select the style from the Styles list. Any currently set parameters are replaced by those of the saved style set. The Styles list contains saved styles as well as a limited number of default styles.
Styles can be renamed and deleted.
Default styles (located in the application folder) cannot be renamed or deleted.
To manage styles:
Click Manage Styles (located in the Styles area at the top left of the tab). The Styles dialog box opens, listing all currently saved style sets and their saved location.
Click
