Shaft Break 2Tool |
Tool set |
Shaft Break 2
Detailing |
To insert a shaft break 2 object.
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default properties. The properties can be edited from the Object Info palette.
Click
to show/hide the parameters.
