Color shaders can use images for image color and as a filtered image. The image color shader can display the image as-is, or can tint the image with a specified color.
The process of selecting an image color shader is illustrated by the following flow chart.
To import an image-based color shader:
Select and import the image as described in Selecting the Image for Import. The Edit Image Color dialog box opens. Specify the image-based shader properties.
