Detail
Callout InstancesDetail callout instances associated with a detail viewport can be added to or deleted from design layers or viewport annotations. In addition, the Detail Callout Instances dialog box provides an easy way to navigate from a detail viewport to its associated detail callouts.
To edit detail callout instances or navigate to a detail callout:
Select the detail viewport whose detail callout you want to navigate to or edit.
Click Detail Callout Instances from the Object Info palette.
The Detail Callout Instances dialog box opens.
Click
to show/hide the parameters.
To add another instance of the detail callout to a different design layer or to the annotations for a different viewport, click on the column next to that design layer or viewport. Alternatively, to remove a detail callout instance from a layer or viewport, click the checked column (which removes the check mark).
Deleting all detail callout instances does not delete the detail viewport, and new instances can be created at any time. However, deleting a detail viewport deletes all detail callout instances.
The detail callout instances can also be used as a navigation tool to access a particular detail callout. Select the design layer or viewport where the detail callout instance is located, and click Activate to switch to the detail callout location; the detail callout is selected for any modifications.
To return from a detail callout instance to the associated detail viewport, click Navigate to Viewport from the Object Info palette of a selected detail callout.
