Copyright and trademark information
Copyright 2016-2020. All rights reserved.
Vision is a product of Vectorworks, Inc.
The Vision documentation is produced by the Technical Publications department of Vectorworks, Inc.
Contributions were provided by Kevin Linzey, Dedrick Duckett, Brandon Budzon, Brandon Eckstorm, Joshua Glassman, Mark Eli, Edward Joseph, and Marissa Farrell. The Vision/Vectorworks diagram is based on a contribution from Caleb Taylor.
This documentation, as well as the software described in it, is furnished under license and may only be used or copied in accordance with the terms of such license. The information in this guide is furnished for informational use only, is subject to change without notice, and should not be construed as a commitment by Vectorworks. Vectorworks assumes no responsibility or liability for any errors or inaccuracies that may appear in this documentation.
Except as permitted by such license, no part of this publication may be reproduced, stored in a retrieval system, or transmitted, in any form or by any means, electronic, mechanical, recording, or otherwise, without the express prior written permission of Vectorworks. Permission is typically granted to reproduce materials for personal use, but under no circumstances may it be used for commercial purposes or for financial gain. To obtain permission, contact Vectorworks (email tech@vectorworks.net) or an authorized Vectorworks distributor if not in the USA.
Existing artwork or images that you may desire to scan or copy may be protected under copyright law. The unauthorized incorporation of such artwork into your work may be a violation of the rights of the author or illustrator. Please be sure to obtain any permission required from such authors.
Vectorworks is a registered trademark of Vectorworks, Inc. Braceworks is a trademark of Vectorworks, Inc.
The following are copyrights or trademarks of their respective companies or organizations:
This software uses libraries from assimp, Open Asset Importer Library. Assimp is released as Open Source under the terms of a 3-clause BSD license. Copyright © 2006-2015 assimp team. All rights reserved.
This software uses code from FFmpeg licensed under the LGPLv2.1, and its source can be downloaded here. FFmpeg is a trademark of Fabrice Bellard, originator of the FFmpeg project.
Xerces-C++ is made available under the Apache® Software License, Version 2.0 (the “License”); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License.
NDI® is a registered trademark of NewTek™ Incorporated.
