Using DMX controls
Command
Path
DMX Controls
DMX
When a lighting console is connected, you can use DMX to control camera views, ambient lighting, and haze direction. Up to nine saved camera views are available from the console. These virtual views are set up and stored within the .v3s file, and they must be patched into an available universe. The DMX information follows the Last Takes Precedence (LTP) priority; the latest information sent takes priority.
The DMX patch information is saved along with the camera views in the .v3s file.
To use DMX for the Vision view:
1.      Select the command.
The Setup DMX Controls dialog box opens.
2.      To activate and control the camera views, select the check box for the camera to use and specify its Universe and Channel number. There are 11 channels per DMX camera.
Channel
Coarse/Fine
Purpose
%: Function
1
Activation
        0–49: Deactivate Camera
        50–100: Activate Camera
2
Coarse
Pan Horiz
        0–0: No pan
        1–48: Pan left
        49–51: No pan
        52–99: Pan Right
        100–100: No pan
3
Fine
4
Coarse
Pan Vert
        0–0: No pan
        1–48: Pan down
        49–51: No pan
        52–99: Pan up
        100–100: No pan
5
Fine
6
Coarse
Orbit Horiz
        0–0: No orbit
        1–48: Orbit left
        49–51: No orbit
        52–99: Orbit right
        100–100: No orbit
7
Fine
8
Coarse
Orbit Vert
        0–0: No orbit
        1–48: Orbit up
        49–51: No orbit
        52–99: Orbit down
        100–100: No orbit
9
Fine
10
Coarse
Zoom
        0–0: No zoom
        1–48: Zoom in
        49–51: No zoom
        52–99: Zoom out
        100–100: No zoom
11
Fine
The view within the viewport changes to that of the selected camera.
3.      To control the ambient intensity, select the check box for this effect and specify its Universe and Channel number.
Channel
Coarse/Fine
Purpose
%: Function
1
Ambient
        0–0: No ambient
        1–100: Ambient value
4.      To control the speed of the haze texture image as it moves in vertical and horizontal directions, select the check box for the haze direction and specify its Universe and Channel number.
Channel
Coarse/Fine
Purpose
%: Function
1
Coarse
Haze Vertical Speed
        0–0: No direction
        1–48: Haze left
        49–51: No direction
        52–99: Haze right
        100–100: No direction
2
Fine
Channel
Coarse/Fine
Purpose
%: Function
1
Coarse
Haze Horizontal Speed
        0–0: No direction
        1–48: Haze left
        49–51: No direction
        52–99: Haze right
2
Fine
Patching
Assigning patch information
Viewing received DMX
Recording and playing DMX files
