DesignSeries00083.pngPick up redline
Command
Path
Pick Up Redline
        Text > Redlines
        Context menu
Once the change or correction indicated by the redline has been resolved, one or more redlines can be “picked up” or changed to a closed state.
To pick up a redline:
1.      Select the redline.
2.      Select the command.
The status of all selected redline objects changes to closed. The redline color changes from red to yellow, and the pick-up date is set.
Redlines can also be picked up by selecting one or more redline objects and selecting Picked Up from the Object Info palette.
Error/revision management using redlines
