DesignSeries00088.pngRedline status worksheet
Command
Path
Create Redline Status WS
Text > Redlines
The redline worksheet lists the status of all redlines in the current file. The Open Redlines section lists all redlines that require resolution; the Closed Redlines section shows all resolved redlines. Each redline item includes the design layer location, date, and redline comment.
To create or open the redline status worksheet:
Select the command. The Redlines Status Report worksheet is created and opens automatically. The worksheet is listed in the Window > Worksheets menu and in the Resource Manager.
Redlines, both open and closed, are listed in the report even if they are currently hidden.
Error/revision management using redlines
