Slot-plug welding symbol Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Welding Sym-Slot Plug
Dims/Notes |
Multiple welding tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a slot-plug welding symbol:
1. Click the tool and mode.
2. Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default properties. The properties can be edited from the Object Info palette.
3. Once the object has been placed, its marker can be selected from the Attributes palette (see Marker attributes).
Click
to show/hide the parameters.
