Angle snapping
Tool
Tool set
Shortcut
Snap to Angle
Snapping palette
S
Two points define an angle; Snap to Angle only applies to the second point of a two-point feedback segment, such as when drawing a line or polygon. When snapping to angles, the SmartCursor finds the angles specified, and by default, the SmartCursor also finds angles relative to the horizontal and vertical axes. Snap to Angle can also detect a plan rotation angle (Vectorworks Design Series required); items created along that angle when in a rotated plan view, appear horizontal when in a non-rotated, world coordinate view.
To activate angle snapping:
1.      Click the tool.
2.      To change settings, if needed, double-click the tool, or select Tools > SmartCursor Settings.
The SmartCursor Settings dialog box opens. From the Angle tab, specify the angle snap settings.
Holding the Shift key while drawing forces the SmartCursor to select the nearest snap angle.
SmartCursor cues
Setting snapping parameters
Drawing with snapping
