Spot00072.pngActivating a video camera
Activate a video camera object to see the same view that a real-world video camera using the same body and lens would capture. Once in the live view, you can re-aim, pan, tilt, and rotate the camera from the Object Info palette and, if a zoom lens is selected, use the scroll wheel or track pad gestures to zoom the camera in or out. For easier editing, you can view a video camera in both a third-person and first-person (active camera) view simultaneously with the multiple view panes feature (see Using multiple drawing views).
Placing a video camera
Linking a camera view to a sheet layer viewport
