The Camera Match photo size
The size of the photo image in the Camera Match object must be set appropriately.
To set the photo size:
1.      Select the Camera Match object.
2.      In the Object Info palette, set the Photo Printed Width or Photo Printed Height to the desired size for the rendering.
For the final rendering, it is recommended to set the sheet layer’s Raster Rendering DPI value in Setting sheet layer properties to match the Sug. Sheet Layer DPI displayed in the Object Info palette of the Camera Match object, or to the desired resolution for final output.
Adjusting the Camera Match control lines and reference target
Camera Match
