Adding socketsDevice objects incorporate any number of input, output, or input/output (I/O) sockets. Since signals typically flow from left to right, place input sockets on the left side of a device and output sockets on the right. Sockets can be named based on the type of connector and the signal they carry, or by a custom naming convention. While sockets can be placed on the top side of a device, that area is normally reserved for the device name label.
Loop sockets loop to connect one socket to an adjacent socket on the same device (creating a “loop-thru”). The Terminator tool adds or removes a terminator on loop-thru outputs.
To add sockets to a selected device:
1. Click the tool that matches the orientation for the socket from the Schematics tool set.
2. Click to place the socket or loop-thru socket on the device.
The Socket Setup dialog box opens.
Click
to show/hide the parameters.
In addition to label information, the socket’s appearance indicates whether it is an output socket (red triangle), input socket (green triangle), or I/O socket (both red and green triangles). Socket appearance can be changed; see Editing devices and sockets.
3. Add a Terminal to a socket if needed by clicking on the socket with the Terminator tool or by selecting Is Terminated from the Object Info palette of a selected socket. This type of socket cannot be connected with a circuit.
If you plan to reuse the device in the future, click Save as Symbol from the Object Info palette of the selected device to save the device as a symbol definition resource.
