Creating reportsThe report commands in the ConnectCAD > Documentation menu create a variety of worksheets for labeling and reporting purposes.
The available commands depend on the worksheet resources in the ConnectCAD template file. Adding worksheets to the ConnectCAD.sta file in your user folder adds them to the menu, for easy access to customized worksheets.
Device reports list jackfield and terminal panels individually, with the number of holes used. This is helpful when trying to optimize patch-panel and term-panel layouts.
Command |
Description |
Creates a worksheet listing circuit numbers and parameters from all layers |
Creates a worksheet listing all circuit parameters from all layers |
Creates a worksheet listing devices and summarizing devices and parameters from all layers |
Creates a worksheet listing circuit numbers and parameters from the current layer |
Creates a worksheet listing all circuit parameters from the current layer |
Creates a worksheet listing devices and summarizing devices and parameters from the current layer |
Creates a worksheet listing the equipment items and parameters from the file |
Creates a worksheet listing all of the rack frames and parameters from the file |
Once a worksheet has been created, two-way worksheet editing is useful for updating the drawing from the worksheet; see Editing drawing objects from a worksheet.
