Placing a rack frameTool |
Tool set |
Rack Frame
Layout |
A rack frame is placed within a rack and it becomes associated with the rack, inheriting the rack’s ID/location and moving along with it. Rack frames are used for modular equipment items. A rack frame can optionally be inserted stand-alone.
To place a rack frame:
1. Click the tool.
2. Click to place the rack frame in the drawing; normally, place the rack frame within an equipment rack. The first time you use the tool in a file, a properties dialog box opens. Set the default properties. The properties can be edited from the Object Info palette.
Click
to show/hide the parameters.
