Angle between two object edges or faces
Mode
Tool
Workspace: Tool set
Shortcut
Edges
Angular Dimension
●        Fundamentals, Architect: Dims/Notes
●        Landmark, Spotlight: Basic and Dims/Notes
. (period)
To dimension the angle between the edges or faces of two objects:
1.      Click the tool and modes, and then select a Dim Std (dimension standard).
2.      Click the edge or face of the first object.
A preview line displays.
3.      Click the edge or face of the second object.
An angular dimension preview displays.
To select a different angle—for example, spanning the opposite direction—move the cursor until the preview displays the desired angle.
4.      Click a third time to define the radius of the dimension.
Angular dimensioning
Editing dimensions
