Angle between two reference lines
Mode
Tool
Workspace: Tool set
Shortcut
Reference Lines
Angular Dimension
●        Fundamentals, Architect: Dims/Notes
●        Landmark, Spotlight: Basic and Dims/Notes
. (period)
To dimension an angle between two references lines:
1.      Click the tool and mode, and then select a Dim Std (dimension standard).
2.      Click to set the start of the first reference line.
A reference preview line displays.
3.      Click again to set the end of the first reference line.
4.      A second reference line preview displays.
5.      Click a third time to set the end of the second reference line.
An angular dimension preview displays.
To select a different angle—for example, spanning the opposite direction—move the cursor until the preview displays the desired angle.
6.      When the preview displays the desired angle, click again to define the angle of the dimension.
Angular dimensioning
Editing dimensions
