Inserting objects
from BIMobject
The BIMobject tool is in the Furn/Fixtures tool set.
A variety of architectural content and furniture with predefined Building Information Modeling (BIM) data attached is available from BIMobject Corporation, a content clearinghouse for architects, landscape architects, and other design professionals. The BIMobject tool allows you to browse and download objects from manufacturer product catalogs, obtain and update product information, and attach extended property set data. Content from BIMobject fits seamlessly into a BIM workflow, allowing you to create BIM-compliant models without the overhead of maintaining and updating valid attached data.
BIMobjects are downloaded as red symbols that contain a black symbol (with the object’s editable geometry) and the data attached to the object. Place the red symbol in the drawing, but edit the black symbol to change the object’s appearance and geometry. The BIMobject is saved in the location specified in BIMobject settings. Edit symbol definitions as described in Editing symbol definitions or Object editing mode.
For access to the BIMobject functionality within the Vectorworks program, first obtain log-in credentials from the BIMobject website. When you begin to use BIMobject functionality, a web browser opens to allow you to log in.
An internet connection is required to use the BIMobject tool.
The following modes are available.
Mode |
Description |
Browse/Download |
Displays products from manufacturers and downloads content to the file and/or to a specified folder; inserts the downloaded object |
Get Info |
Displays the manufacturer product data of the selected BIMobject |
Update selected |
Updates all BIMobjects with the latest manufacturer product data |
BIMail |
Opens the BIMail dialog box; this interface provides a way for content manufacturers to communicate with designers regarding product updates, changes to specifications, and discontinued products. |
User settings |
Opens the BIMobject User Settings dialog box, to set the default location for downloaded content |
When opening a file with BIMobjects from a version prior to Vectorworks 2018, the Update BIMObjects dialog box opens. Select what to do with older versions of the BIMobjects.
Click
to show/hide the parameters.
