DesignSeries00014.pngRotating the geolocated image
Mode
Tool
Workspace: Tool set
Rotate
Geolocate
        Architect and Landmark: GIS
        Spotlight: Event Design
Rotate mode changes the orientation of the background image, which is necessary when angle to true North prevents proper alignment of the geolocated drawing. The mode uses a 3-click operation, similar to the Rotate tool.
The Rotate mode will change the Angle to True North value in the Document Georeferencing dialog box.
To rotate the geolocated image:
1.      Click the tool and mode.
2.      Click once to set the origin, then click a second time to establish the reference line.
3.      Move the cursor to rotate the background drawing.
4.      When properly aligned, click a third time to set the position of the background image.
To undo the rotation, set the Angle to True North parameter in the Document Georeferencing dialog box to 0 (zero).
Geolocating the drawing
