Placing irrigation controllersTool |
Tool set |
Controller
Irrigation |
The Controller tool places an irrigation controller object, representing the electronic devices that are programmed to control valves. Controllers with parameters from a selected manufacturer are available, or a controller can be placed as a custom controller with parameters that can be specified after placement. Controllers do not connect to irrigation networks.
To place a controller on the drawing:
1. Click the tool, and then click Controller from the Tool bar. From the Resource Selector, double-click a resource to activate it. Select from one of the manufacturer libraries, or select the custom resource from Custom.vwx and set its properties after placement.
2. Click once to place the controller.
The controller properties can be edited from the Object Info palette.
Click
to show/hide the parameters.
