Command |
Path |
Manage Scenes |
Spotlight > Visualization |
To save a scene:
1. After the lighting properties for all the instruments have been set correctly, select the command. The Manage Scenes dialog box opens.
2. In the Scenes list, the list of saved scenes is displayed. The scenes are sorted by the order in which they are entered. To save the current settings as a scene, click Save. The Save dialog box opens.
Click
to show/hide the parameters.
3. Click Done to save the scene. It is added to the Scenes list.
To edit a scene:
1. Select the scene from the list in the Manage Scenes dialog box and click Edit.
2. Make the desired change to the Scene Name or Number, or the Up/Down Time, then click Done to save the change. Confirm the changes.
To remove a scene:
1. Select the scene from the list in the Manage Scenes dialog box and click Remove.
2. Confirm that you wish to remove the scene, then click Yes. The scene is removed from the Scenes list.
To restore lighting parameters from a scene:
1. Select the scene from the list in the Manage Scenes dialog box and click Go!.
2. Confirm that the parameters are to be restored. The current light parameters are replaced by those from the scene.
All current levels, colors, positions, and focus points for all the instruments will be replaced. Any information that has not been saved will be lost.
