Arch00006.pngCreating a circuit
Tool
Tool set
Circuiting
MEP
To create a circuit:
1.      Click the tool.
2.      Click the first item to be circuited.
If you select a custom symbol without a Circuiting record attached, the tool attaches the record to the current symbol, as well as to all subsequent symbols in the circuit. In this case, specify whether an electrical or communication circuit is being created.
When creating a circuit, do not include the panel symbol.
Based on the item’s record, the tool determines whether this is an electrical or communication device. The Circuiting Tool dialog box opens.
3.      Enter the desired information for the circuit and the objects in the circuit.
The information is transferred to the object’s record.
4.      Continue clicking on the items to be circuited in the order the circuit loop should be drawn.
5.      To complete the circuit, click in an empty area of the drawing. Confirm that you wish to place the Home Run marker.
The Circuiting tool generates a Home Run marker and phases are denoted as specified.
