Creating existing trees
from lociCommand |
Workspace: Path |
Create Existing Trees from Loci |
● Designer: AEC > Existing Trees ● Landmark: Landmark > Existing Trees |
Loci with tree survey data, which may have come from a survey file, imported DXF/DWG file, or point-based shapefile, can be converted to existing tree objects with the proper attached information, including location. By mapping the attached data to the existing tree record fields, valid existing tree objects are created in the Vectorworks Landmark file.
To create existing trees from loci:
1. Select the loci, or select symbols that contain the loci.
2. Select the command.
The Create Existing Trees from Loci dialog box opens.
Click
to show/hide the parameters.
3. If using a record attached to loci as the basis of the existing tree parameters, select the record, and then select each row of the record mapping table. Specify how each row should be mapped to the equivalent existing tree parameter by selecting it from the Selected Existing Tree Parameter. If necessary, select the specific units that should be used if they are different from the document defaults.
When mapping to existing tree parameters, the associated data values are mapped directly when the type is compatible. For example, when the height parameters are mapped, the height value from the record becomes the Height value for the existing tree; a mapped Condition parameter is set as expected if the entry matches one of the default options (Excellent, Good, Average, Poor), or to Custom if the entry does not match the defaults.
If no data are provided for mapped parameters, the default values of the Existing Tree tool are used.
4. Save the mapping settings if needed.
5. Click OK to create the existing tree objects from the loci.
