When opening a file that contains sheet border objects created in versions of Vectorworks prior to 2018, the objects must be converted to title block borders to function properly in the file.
To convert sheet borders to title block borders:
1. Select a sheet border object, and either click Update on the Object Info palette or, in Design Series products, right-click and select Update from the context menu.
The Update Title Block dialog box opens.
Click
to show/hide the parameters.
If you opt to convert all sheet borders in a selection of files, the Select Files dialog box opens. If not, skip to step 4.
2. Click Select Folder and browse to the folder with the files to select.
The list browser displays the .vwx files located in the folder.
3. Select the folder that contains files to convert, and click to place a check mark in the Use File column to the left of the files to add.
4. If Show the Properties Mapping dialog is selected, the dialog box opens and displays the default Project Data and Sheet Data mapping. Change the mapping as needed and click OK to return to the Update Title Block dialog box.
Some fields, such as File Name and Sheet Title, cannot be remapped.
Click
The sheet border is converted to a title block border and parameters are mapped to the new fields. Parameters that cannot be mapped are given default settings.
The title block border object aligns the title block relative to the sheet border differently from the previous sheet border object. If you experience incorrect alignment after conversion, consider changing the Constrain Title Block setting on the Title block border settings: Title Block pane, or see if there is a outlying locus that can be deleted to correct the alignment.
