Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Rectangular Tubing
Detailing |
The Rectangular Tubing tool and Rectangular Tubing - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To create rectangular tubing:
1. Click the tool and mode.
2. Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default properties. The properties can be edited from the Object Info palette.
Click
to show/hide the parameters.
