Tool |
Tool set |
Shaft Break
Detailing |
To insert a shaft break:
1. Click the tool and mode.
2. Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default properties. The properties can be edited from the Object Info palette.
Click
to show/hide the parameters.
