Editing section lines and section-elevation markers
After creation, edit section lines and section-elevation markers as follows:
●        Use the Object Info palette to edit the graphic properties (such as the marker style).
●        Use the Attributes palette to apply attributes (such as the fill or pen color).
●        Use options on the Text menu to control the text appearance (such as the font or size), or assign a text style.
●        Use the Selection or Reshape tool to edit the objects (see Modifying section lines graphically).
●        A section-elevation marker can be linked to a viewport by selecting the viewport from the Link To Viewport list on the Object Info palette (Design Series only).
Section-elevation marker properties
Parameters display on the Object Info palette for selected section-elevation markers.
DesignSeries00026.pngSection line properties
Section-Elevation Marker tool
Creating a vertical section viewport
Viewport properties
Modifying viewports
Viewport status
Updating viewports
