DesignSeries00043.pngSetting horizontal section viewport cut planes and extents
You can control the cut plane and extents of a horizontal section viewport itself, and you can also create different settings for individual 3D objects when viewed within the horizontal section viewport.
When the section viewport is created from a clip cube, the cut plane and extents are automatically set to match the clip cube.
To set the cut plane and extents:
Click Cut Plane and Extents from one of the following locations, and set the parameters in the Cut Plane and Extents dialog box.
        The Create Horizontal Section Viewport dialog box
        The Object Info palette or Properties dialog box of a horizontal section viewport
        The Cut Plane and Display dialog box for one or more selected eligible objects; see Displaying individual 3D objects in section viewports
The Cut Plane and Extents dialog box opens.
The cut plane and extents are set for the viewport, or for the selected objects, depending on how the dialog box was accessed.
Creating a horizontal section viewport
Advanced section viewport properties
