Connect00070.pngPresenting schematic and layout diagrams to clients
The ConnectCAD template includes three sheet layers, Schematics, Rack Layer Elevations, and Rack 3D Layouts. These sheet layers already contain viewports which automatically display the associated design layer correctly for presentation. You can edit the scale, rendering, annotations, and so on, as needed. Title block borders are already present and ready to customize. Along with the worksheets which report the necessary components, quantities, and other parameters, you have everything you need to present the final project to your client.
创建图纸图层视口
视口特性
字幕栏边框
