Command |
Path |
Render Still |
Render |
Vision allows you to create still images of the Scene window displaying the current lighting status. When the Scene window displays four viewports, the bottom right viewport is used to create the image. Still images are saved in .jpg format. Specify the image render settings, and optionally save them as a preset. For more information on saving and managing the Render Still presets, see Using saved sets.
To save the Scene window as a still image:
1. Properly configure the scene and create the desired lighting look.
2.Select the command.
The Render Still dialog box opens.
Click
to show/hide the parameters.
3.Select a set of image render settings from the Settings Preset list, or select <Active Settings> to use the settings currently specified in the Vision Preferences dialog box.
4.Click Customize to specify the image render settings.
The Vision Preferences dialog box opens, but only the Graphics tab is available. The top portion of the dialog box offers options for saving and managing presets. The Graphics tab displays the rendering parameters. Set the parameters as desired.
Click
5.Do one of the following:
● To save the currently specified settings as a preset, see Using saved sets.
● To use the currently specified settings without saving them as a preset, click OK.
6.From the Render Still dialog box, select the image Resolution. If the image will be printed, set the dpi.
For finer control of the print size, set the Resolution to Custom Print Size and specify the Print Size dimensions.
7.Click the button next to the Output Filename field, and set a name and location for the image file.
8.Click Render to save the image.
