Tool |
Tool set |
Drawing Label
Dims/Notes |
The Drawing Label tool adds descriptive information to a drawing, such as title, scale, and drawing and sheet numbers. Alternatively, when creating a viewport, you can opt to add a drawing label to the viewport annotations.
The alignment modes temporarily override the label’s defined insertion point, for precise placement.
Mode |
Description |
Align Object Left |
Insertion point is the left edge of the label’s bounding box |
Align Object Center |
Insertion point is the center of the label’s bounding box |
Align Object Right |
Insertion point is the right edge of the label’s bounding box |
Align Object Origin |
Insertion point is the label’s originally specified insertion point |
Style |
Opens the Resource Selector to select a drawing label for placement; double-click a resource to activate it |
Preferences |
Sets the default parameters that are used for each new drawing label object |
To add a drawing label:
1. Click the tool and mode.
2.Do one of the following:
● Click Style on the Tool bar to select a resource from the Resource Selector.
● Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Click
to show/hide the parameters.
3.Click to place the object, and click again to set the rotation.
Once a label is in the drawing, you can edit it from the Object Info palette. The following additional options are available when editing drawing labels.
Option |
Description |
Style list options |
● Replace: Applies a different style to this object ● Convert to Unstyled: Allows you to modify the settings and label layout for this object only ● Edit Style: Allows you to modify the settings and label layout for all objects in the drawing that use the current style See Creating styles for markers and drawing labels for details. |
Edit Drawing Label Layout (unstyled labels)
Opens an editing window to change the geometry and text in the label; see Creating styles for markers and drawing labels |
