Fit to objects
Command
Path
Shortcut
Fit to Objects
View > Zoom
●       Ctrl+6 (Windows)
●       Cmd+6 (Mac)
●       fit_objects_button.png (View bar)
The Fit to Objects command provides an easy way to zoom in and out of a drawing. There are two options: fit the window around all the objects in the drawing, or fit the window around a particular object or set of objects.
When in an uncropped perspective projection, the view direction is preserved, and the viewpoint is adjusted to fit the model or object within the drawing window.
To fit the drawing window around all visible objects in the drawing:
1.      Ensure that the current layer contains the objects to view, and that no objects are selected.
2.Select the command or click the View bar button.
The program zooms in or out so that all the objects in the drawing display in the drawing area.
To fit the view to a particular object or set of objects:
1.      Ensure that the current layer contains the object to view.
2.Select the object or objects to view.
3.Select the command or click the View bar button.
The program zooms in to display only the selected object in the drawing area.
Zooming
Fit to page area
