Spot00108.pngChecking the cross section workload
Command
Workspace: Path
Cross Section Workload
●       Spotlight: Customize workspace to add command (see Customizing workspaces)
●       Braceworks: Braceworks
The Cross Section Workload dialog box analyzes the workload and structural properties of the cross sections that participate in calculations. While Braceworks is required for the calculations, Spotlight users can use this command to check the properties of the cross sections in the drawing and check for potential problems.
To check the cross section workload:
1.      Select the command.
The Cross Section Workload dialog box opens.
2.Select the Cross Section from the list to view its properties.
Specifying cross section data
