Command |
Path |
Replace Truss Type |
Spotlight > Rigging |
If a truss line or system was designed with a truss type that is not currently available in the inventory, the type can be replaced with a type that is available.
Since a truss system consists of truss lines all of the same type, all of the truss lines in the system (or all trusses in a truss line) are replaced by this command, even when just one truss is selected. Sufficient inventory is required to make a replacement, so ensure that the inventory is up to date by Managing truss inventory.
To replace the truss type:
1. Select a truss in a truss line or a truss system.
All trusses of this type within the line or system will be replaced.
2.Select the command.
The Replace Truss Type dialog box opens.
Click
to show/hide the parameters.
3.Select the replacement Truss Type from the list.
The Replace with mapping occurs automatically for straight truss sections when sufficient inventory exists.
If there are no replacements available in inventory for any given section, the truss type replacement cannot occur.
4.For circular or linear truss elements, automatic mapping cannot occur. Select each element and choose its replacement from the Select Corner/Circular Truss Resource Selector.
5.Select a Top or Bottom Alignment Option for the replacement, and specify an Offset if needed.
